Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
 How do I visually add a prop in G3 >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 02-18-2006 | 05:13 PM
Rat1's Avatar
Default How do I visually add a prop in G3
I was doing something with a downloaded shocky 330 and lost the visual prop.
Yes it was Ricks 330 shocky. I changed the fuse design from rootframe to cs_mmvs. When I did that the prop disapeared from view. I tried changing it back but the prop did not come back.
This helped cure the ability to hold a knife edge. I tried adding a second horizontal fuse like a real shock flyer but this would not let me pull the tail over the top. I have no way of changing the dimensions of a horizontal fuse so that it is narrower at the tail then at the nose.
Sure would be nice if Knifeedge would fix this editing problem. They need to also change the adding options so we can add a visual prop if need be.
So if anyone could give me a hand with these two issues (the prop and the horizontal fuse) then please let me know. I can try and send the the plane for them to fix and send it back to me. [email protected]
Old 02-18-2006 | 08:40 PM
HuckinChikn's Avatar
Default RE: How do I visually add a prop in G3
not sure about the prop thing..the only thing i can think of is under the *engine* selection there is the *prop visual scale* that you can change, but i dont know if that would have anything to do with it. By the way, Where did you get the shocky?? I want it!!!
Old 02-19-2006 | 10:48 AM
Rat1's Avatar
I have looked all over in the editor but can find no way of getting the prop back. I even tried changing fuse design back to what it was before hand and that did not work either.
So if the originator of this shocky would be willing to give me a hand to get the prop back, it would be great. Or someone with the program to create G3 models.
Old 02-19-2006 | 04:33 PM
3DSAVAGE's Avatar
so my advise on rcmac didn't work?
Old 02-19-2006 | 07:03 PM
Rat1's Avatar
ORIGINAL: 3DSAVAGE
Nope. Looks like I am batting a no hitter on getting some help.
