RCU Forums - View Single Post - My CG Machine
Old 02-19-2006 | 01:56 PM
eardoc
Default RE: My CG Machine
I can't believe this was so easy and accurate. I'll never try balancing 28 lb models on my fingertips again.
One difficulty I found was accurately converting measurements on the table top (between wheel contact points), up to the fuse. I ended up using a plumb line which worked well. Seeing the more recent posts I'm now going to make all measurements from the nose, using a square to align the nose with marks on the table.
This is the first time I have had enough confidence in the measurements to start pulling lead out of the nose.
Very valuable thread. Thanks TommyWatson.
