LT 40 throttle linkage
I'm putting together a LT 40 with a Magnum 52 four stroke. I am trying to figure out the best way to run the throttle linkage. With the throttle arm behind the cylinder, there's no way to bend a push rod to connect to the arm. I know there is a bell crank system that you can connect to the engine mount and go thru the firewall and then back to the throttle arm. Does anyone have some pics of a set-up like that? or an alternate method of routing the linkage?
