RE: BRIO Construction by the numbers
Now, the gear plate tabs. Cut through the bottom deck for access to the gear plate. Use a piece of paper to make the reinforcing tab template, then cut a 3/4 strip of light 1/8 inch ply and make the 4 tabs. Next glue them in with some thick CA.
