RE: OS 140 RX questions
Hi Troy,
I've have used the OS 140Rx now for the past 4 years, for the pipe I've used both the T. Prossor pipe (bought through Model Sports) and the Hatori #900 pipe, both worked the same, you can pick up the Hatori pipe through Singapore Hobbies at a good price if you want to order from oversea's, if not I would buy the Prossor pipe in Aus, better price than the OS / Hatori pipe bought here in Aus.
I'm also using the Hyde OS140 ARA engine mount at the moment, great mount very light. Would use again.
As for servo's I agree with last two replies as to stick with my choice of Futuba servos but JR are just as good and not too try those other servos, the extra price is worth it in the long run.
Dauphin
