RCU Forums - View Single Post - 8u works and 9z doesn't
Old 02-20-2006 | 03:16 PM
Bax
Default RE: 8u works and 9z doesn't
Some non-Futaba receivers will not operate with the Futaba 9Z transmitter when the 9Z synthesized module is used. Those receivers don't have a problem with the fixed-frequency modules.
The 9C synthesized module you're using in your 8U transmitter has a slightly-different coding that those non-Futaba receivers can accept.
Futaba does guarantee that all Futaba receivers will respond to Futaba transmitters as long as the frequency and coding are correct.
