RE: Fuji 32 Crankcase cracking
Is it a common problem for the cases to crack at all? Because when the case cracks the engine usually will not idle well and sometimes quits while in flight. The B25 being a twin, I'm sensitive to losing an engine in flight. Can you recommend any precautions I should take to help insure the engines don't have an issue?
Steve
