RCU Forums - View Single Post - slipping pushrods
Old 02-23-2006 | 08:20 AM
Mode One
Default RE: slipping pushrods
I think it's likely you are trying to secure a push-rod that has a diameter which is to small for the connector you are using. I asume you are using the EZ Connector type connection. Replace the connector with the proper sized connector for the push-rod your trying to secure, or go up in diameter with the push-rod.
