OK, what is Luke going to come up with next? Let me see.... hummmm...I got it! An automated gound support crew to service his hellcat once the plane lands
Luke, you are amazing with your talent! Keep on keepin' on brother!
For those of you who are using CJ retracts with 4 inch wheels, are your wheels sticking out above the surface of the wing at the trailing edge about 1/4 to 1/2 inch? I dont see that there is anything I can do about it tho. My retract mount is below the balsa sheeting by 1/4 inch or so at the leading edge and gets even lower as it goes toward the spar (using the stock hardwood pieces supplied that I have not glued in yet) Did any of you change the hardwood out to get your retract mount even with the balsa sheeting? Or what did you do to solve this?
Thanks!
J
