ORIGINAL: HalH
The area that you found was soft is probably just a space between the outside skin and a former. I found several spots where there were gaps between the formers and the fuselage. If you cut off the tailcone, you will be able to see the problem. I would not recommend adding glass ! To use Lukes cockpit kit you will have to cut the stock cockpit out and remove some material on the inside.
Thanks Hal. I'll look at the area again. The soft area seems to be between formers.
BTW...I ordered the retracts today from Darrell at Sierra. Thanks for the tips.
John
