RE: JetTronics valves. Help needed
Bob, you need to use the stock JetCat 3mm line supplied with the turbine. I had the same problemm trying to use stock air line. Use regular air line going to the brakes, but from where it T's to the valve install the 3mm line.
Hope this helps,
Dave
