RE: Carb Leaking? pics
would the 4to 5 tanks be on the same day? If not shame on you.
Adjust the idle screw slightly higher than you want then adjust the LSN when you get the engine to tick over to its highest richen slightly and then adjust the idle down to where you want it.
To check if it is correct do the pinch test.
