RCU Forums - View Single Post - Elevator deflection
Old 02-24-2006 | 11:04 AM
Bax
Default RE: Elevator deflection
Please check this with a different servo plugged into that slot in the MSA-10. It may be something in the servo, or the MSA-10. It shouldn't do that. If you can, please check to see if you get the same difficulty if you use Futaba servos connected to the MSA-10.
It may have something to do with the mix of Futaba and non-Futaba equipment.
