Elevator deflection
My Feedback: (8)
IN
I'm using a MSA 10 on my elevators ( one servo per) and everytime I turn on the plane one servo will go to extreme up then back to center, will be fine after that, Why? I'm using 8611 servos w/ Futaba 9CAP W/ PCM 149. Is it because they are JR servos?
Thanks, [
] Lee
Thanks, [
] Lee
Please check this with a different servo plugged into that slot in the MSA-10. It may be something in the servo, or the MSA-10. It shouldn't do that. If you can, please check to see if you get the same difficulty if you use Futaba servos connected to the MSA-10.
It may have something to do with the mix of Futaba and non-Futaba equipment.
