RCU Forums - View Single Post - Roto-Tech Starter
Old 02-24-2006 | 04:41 PM
mulletman
Default RE: Roto-Tech Starter
ORIGINAL: bounty
Thanks will check it out, is it easy to replace the pull start with the tiger drive solution?
yes, all you do is take the engine out, take the pull starter off and replace it with the tiger drive. Put the motor back in and your done
