CEN Racing This forum is to discuss all CEN Racing products.
Roto-Tech Starter
Old 02-21-2006 | 10:58 AM
Default Roto-Tech Starter
Is it possible to modify my CT5 to all for it to use the Roto-Tech Start, which the Genesis uses? Can someone tell me how?
Or would it be better to use a Box Starter and how?
Or is there a site which can put me in the right direction for this sort of conversion?
Old 02-22-2006 | 10:57 PM
Default RE: Roto-Tech Starter
I dont think you can. Even if you put the backplate on, the shaft wont be able to access it
Old 02-22-2006 | 11:06 PM
DO a search for a tiger drive. I don't have a ct5S but i have one on a cen FF and it works great. I think it is made by sullivan products
Old 02-23-2006 | 07:02 AM
Thanks will check it out, is it easy to replace the pull start with the tiger drive solution?
Old 02-23-2006 | 07:39 AM
RC30GTR I know you said you don't think it is possible, but would it be possible using a Starter Box?
Old 02-24-2006 | 04:41 PM
ORIGINAL: bounty
yes, all you do is take the engine out, take the pull starter off and replace it with the tiger drive. Put the motor back in and your done
Old 02-24-2006 | 04:57 PM
cool thanks again for the information
Old 02-25-2006 | 01:17 AM
CEN Racing's Avatar
Roto-Tech unit will be blocked by the exhaust manifold. THe eaiset way is to used a starter box.
Old 03-01-2006 | 08:02 AM
Thanks I am going with the starter box
