RCU Forums - View Single Post - Motor/ESC/Battery Question???
Old 02-24-2006 | 08:55 PM
pootman
Default RE: Motor/ESC/Battery Question???
Thanks for the reply. Now the 31.5 amps continuous and 50 amp burst you mentioned, is that the max amps the battery will provide regardless of motor demand or is that the max amps that a motor can draw on the battery without overheating it (battery)? Basically, if my motor is rated with less amp demand than the battery provides, will that burn up the motor or will the battery provide only what the motor demands and no more?
