RCU Forums - View Single Post - Tipo info
Thread: Tipo info
Old 02-24-2006 | 10:33 PM
impactiq
My Feedback: (57)
Default RE: Tipo info
The WK Tiporare is a better one when compared to the GP kit. The glass/epoxy work is where the difference is. I have both versions. The GP Tipo fuse is prone to stress cracks.
The ailerons are done as you mentioned. By gluing 2 pieces of wood together,it make for a stiffer aileron that should not flex at higher speeds.
The answer to your question about the rear exhaust..... I have done 2 with rear exhaust engines in the past. The biggest problem with the rear exhaust In a Tiporare is the amount of material that is removed from the side of the fuse and firewall (to clear a header) when the engine is installed. In the original Tipo plans that were published in MAN. It recommends that the amount of Anhedral in the stab be decreased when using a rear exhaust engine. I did one both ways with little difference between the two.
As far as the tuned pipe goes... The thing here is to keep the pipe straight with the center line (a good reference is the seam where the fuse sides is joined together) of the fuse. A tuned pipe that is cocked to one side could cause unwanted yaw in a maneuver.
