RCU Forums - View Single Post - Items in your field box
Old 02-25-2006 | 07:25 AM
piper_chuck's Avatar
piper_chuck
My Feedback: (12)
Default RE: Items in your field box
ORIGINAL: skymortar
a cooler full of ice,a freind who wont tell your other freinds youre an idiot,organ donor status updatedand i have a question.im building a goldberg cub.i bought a futaba 4exa with three 5310m38 servos.can i run my offshore nitro boats with this radioi already posted in the radio forum.shocker,noone was there.my question is did i buy a descent radio
I'm assuming that your 4EXA is in 72mhz, the aircraft band. If so, the answer is you absolutely can not use it for boats, or cars. FCC regs provide separate bands for surface and aircraft to minimize the chances of interferance. Get yourself a good 2 or 3 channel radio for the boats. Also, in case you haven't discovered yet, there are several boat clubs up your way if you're interested in running with others. Go to http://www.impba12.com/ for more info.
Edit: I haven't used the 4exa, but I've got it's big brother, the 6exa. The 4 channel version should be a good introductory radio. However, if you haven't flown before, the Goldberg Cub is not a good choice for a first plane. A trainer would be much better.
