RCU Forums - View Single Post - fuel tank
Thread: fuel tank
Old 02-25-2006 | 10:30 AM
waagbuck's Avatar
waagbuck
Default RE: fuel tank
You should be able to pump the fuel out of the tank. If you have a blockage, just disassemble the tank, remove the blockage, and reassemble. If you want more detailed instructions, post more details -- what plane do you have? what engine? Is it a two-line tank or a three-line? Are you using the tank that came with an ARF, or an after-market one? Good luck!
