fuel tank
should i be able to draw fuel out of the fuel line with my pump to remove the fuel out of the plane I think i have a problem it is blocked and cant get the fuel out and i think this is making the motor die in flite thanks for any help.........
VA
You should be able to pump the fuel out of the tank. If you have a blockage, just disassemble the tank, remove the blockage, and reassemble. If you want more detailed instructions, post more details -- what plane do you have? what engine? Is it a two-line tank or a three-line? Are you using the tank that came with an ARF, or an after-market one? Good luck!
this is stock tank for a funtana 40 and two line it is all new but i got it ready to go but i have trying to find the motor sickness and think this is it it is a magnum 70 xls thanks
