RE: Pull Pull on 35% Panzl
Here are the pics. Tiller arm is 41" from hinge line. Balances ok there, just a little nose heavy, balancing at the wing tube with no wings. I used the Dubro heavy duty connectors in the rudder. It helps get the connection at the hinge line. If you can see in the picture, the connector hits the fuse before max travel, still get a lot of travel though. Looking for any ideas to solve that problem. I believe my tiller arm is 4"
