RE: Charging NiMH
I'm not familiar with the swallow delta v fast charger, but if it is designed for NiMh packs, then you can use it unattended. Even if it is designed for NiCd, you can generally use it for NiMh. If you overcharge NiMh, you might ruin the pack, but they do not tend to burst into flames.
