RE: Pull Pull on 35% Panzl
Edge, I believe you must be the guy SWB mentioned when I called as he said he had just sold one for a Panzl. I guess the only thing you could do would be to shorten the black arm but that will throw out your setup on the hinge line unless you re drill the hole closer to the hinge.
