RE: Gyro Problems
pilot, before you change the gain (which should be set at 50%) which is a good starting point. I need to know a couple of things. what tail servo are you using? Where is the gyro mounted in reference to the other electronic equipment? Also remember that you dont want to mount the gyro too close to other equipment. And dont rap the other wires ( ESC,motor wires, etc.) together , they can cause enterference with the tail servo/gyro. Mike
