RE: Gyro Problems
thanks for the advice, the gyro wires are wraped with other stuff. im using bms bluebird 380 servos. i have ballenced the blades as best i could, should i buy a blade ballencer?? if so.. which one? as well.. ive been reading some other forums and they mentioned a helihobby glich reducer? does that help? also... i found that the deans antena causes ALOT of intefearence problems so i stopped using it. the gyro is kinda in the front secured with the velcro u kno where they tell u to in the manual.. should it be somwhere else?? thanks alot
Josh
