RCU Forums - View Single Post - Is an os .46 fx suitable for a sig LT-40?
Old 03-01-2006 | 01:39 PM
Sarges_heroes2003's Avatar
Sarges_heroes2003
Default RE: Is an os .46 fx suitable for a sig LT-40?
ORIGINAL: Mxer82
Which engine would you put in a sig LT-40? An os surpass .52 or an os .46fx? I already have both engines(picked them up real cheap, brand new) Keep in mind I am just learning to fly. Thanks
Tim
I tried flying the lt with a os 42 la on it but it just barely had enough power to get off the ground and go around in circles. I got a 46 la and It worked good. plenty of powa to learn the touch and go and do other stuff, eventually my luck ran out and the lt went into a dive and would not respond. post crash inspection showed the excess servo wires got wraped around the servo arms. it can happen after a good roll or to and is common to trainer type rc aircraft becuase of how they have the servos installed. look out for that or yours will suffer the same fate.
