Tools needed
For one CA (glue)-Epoxy or JB Weld which ever required for clutch liner adhesion
LockTite (must)-For any nut or bolt that does not have the nylon insert to prevent loosening.
Phillps screw driver larger bit & Auger small sized
Allen Driver Set
Ruler I use mm
Needle Nose Pliers
Scissors For Decal if used
Nut Drivers
You will need a blade balancer & pitch gauge, you might could borrow these from another flyer.
Ball Link Pliers are a huge plus....
