Tools needed
Am about to start building a Raptor 30 V2 from scratch.
What tools will I need to successfully complete this project.
Is there a tool that you have that you couldn't do without.
By sorting this out first I aim to reduce the build time (i.e not having to pop out and get extra tools to complete each part)
Look forward to receiving your replies
My Feedback: (14)
AL
For one CA (glue)-Epoxy or JB Weld which ever required for clutch liner adhesion
LockTite (must)-For any nut or bolt that does not have the nylon insert to prevent loosening.
Phillps screw driver larger bit & Auger small sized
Allen Driver Set
Ruler I use mm
Needle Nose Pliers
Scissors For Decal if used
Nut Drivers
You will need a blade balancer & pitch gauge, you might could borrow these from another flyer.
Ball Link Pliers are a huge plus....
Allen Driver Set
Ruler I use mm
Needle Nose Pliers
Nut Drivers
