RE: Aeroworks 27% Ultimate
Great thread, Great plane!
One thing i havent heard , has anyone noticed excessive slop side to side with the center cabane?
I did on mine, especially when I would carry the plane from the center cabane.
The fix is simple- cut a square out of the top of the fuse, using the 4 corners of the cabane holes as refrence. Pull the 'plug' out, build 2 bulkheads between the 2 sets of uprights, plop the plug back in, recover.
Another mod i did was to make a removeable plate on the bottom of the fuse under the wing for an access hatch, pulled the dowels out of the wing, replaced them with 1/4 20 nylon bolts, and cinched the wings tight with nuts from the inside.
I love this plane, it'll do it all. spend some time programing and mixing out, and the skys the limit
Happy Flyin'
Ted
