RCU Forums - View Single Post - How To Do A Removable Rudder
Old 03-04-2006 | 07:09 AM
BTerry
My Feedback: (8)
Default RE: How To Do A Removable Rudder
I have done this in the past using a single, removable rod acting as the hinge pin on Dubro Heavy Duty hinges (with the removable cotter pin). Basically the hinges are lined up so the music wire pin can run directly through all of the pivot holes. The music wire is bent in an "L" shape, with the short secured to the bottom of the fuse or top of the vertical fin so it won't fall out.
I don't know whether this would work on the Genesis (I don't know anything about the kit), but it may be worth a try.
