RCU Forums - View Single Post - 9C programming questions
Old 12-04-2002 | 10:02 PM
N55340
Default 9C programming questions
I'm trying to setup a complex configuration for a plane. I've checked the faqs on Futaba's web site and I'm close. Perhaps I can't quite follow the directions. Here are the functions I'm trying to get:
Flaps set to the left slider switch and get proportional down elevator movement.
Couple ailerons to rudder on a switch. On or off.
Crow configuration on a switch coupled with elevator
Also have the amount of crow decrease as throttle is increases.
Couple ailerons to elevator on a switch so when on the ailerons will respond like the elevator while still allowing aileron control.
All of this in Airplane not Glider mode.
Thanks!
