Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9C programming questions
Old 12-04-2002 | 10:02 PM
Default 9C programming questions
I'm trying to setup a complex configuration for a plane. I've checked the faqs on Futaba's web site and I'm close. Perhaps I can't quite follow the directions. Here are the functions I'm trying to get:
Flaps set to the left slider switch and get proportional down elevator movement.
Couple ailerons to rudder on a switch. On or off.
Crow configuration on a switch coupled with elevator
Also have the amount of crow decrease as throttle is increases.
Couple ailerons to elevator on a switch so when on the ailerons will respond like the elevator while still allowing aileron control.
All of this in Airplane not Glider mode.
Thanks!
Old 12-05-2002 | 01:20 AM
N5,
Please see the FAQ for the complex 7 servo aerobat. it will give you almost all of it. set it up, do one piece at a time, make sure that piece works properly. from what you learned there, try to create the other mixes yourself. then pop back and let me know what still isn't working and i'll be happy to help.
Hint#1: your "flaps" are NOT what your radio is talking about when it says "flaps". youve turned on flaperon and therefore the aileron servos moving together as flaps is what the radio means when it says flaps. elevator to flap mix will give you your last desired function.
