RE: Webra Speed 50
Its 11:30 AM here in central Illnois and I just came in from the back yard where the temp is 42 degrees. The Webra started just fine with the OS 8 glow plug. Still same old problems Idle good, sputter on transitation, full throttle seemed rich. Leaned it out a few clicks also leanded out the low speed needle about 1/4 turn. Started and stopped the engine a few times always starts easy. Still had the problem coming from full to 1/2 throttle, the engine would slow down and die. It wouln't die if I came from 1/2 to idle. Made a few more minute adjustments on both high and low speed needles and it seems to be running the best I have ever had it. It still sputters a bit after about 30 seconds of idle time and then give it full throttle. If I run it up to full throttle and back to 1/2 throttle now at least it don't die. I run about 12 oz of fuel thru it makeing all of these adjustments. I got the plane on charge now and I think I will go out to the field this afternoon and see what it does. Oh well I am getting a lot of practice on dead stick landings. Thanks for your help.
