RE: Webra Speed 50
The Fox RCLONG idle bar plug is about the same temp as OS#8 . After a 30 second idle and it sputters a little too full throttle lean out low speed about 2 clicks clockwise. Less than 1/8 turn. Your still not broke in so low speed needle will probably change later.
