RCU Forums - View Single Post - hi po ryobi?
Thread: hi po ryobi?
Old 03-04-2006 | 01:33 PM
flyjoe540's Avatar
flyjoe540
Default RE: hi po ryobi?
ok going to do it! ill start small though, bowman ring electronic ignition with advance (i know i dont need it but i want the experience with it for larger conversions)
now can i eliminate the gasket between jug & piston to increase compresion? my piston hits counter weight without the gasket it just scrapes a little.is this normal? can i remove material from piston skirt for clearence?(yes i have it in corectly)
i was also contemplating stuffing it? i have read this will this help increase performance
how about a larger carb? any suggestions on a size?
can i open up exaust port? do i need to blue print it first? what is a good duration for the ryobi ? icant find this info anywhere
any help is appreciated
fj5
