RE: shock trouble
Whats up Mjs.
Leave about 1/4 of a inch of space from the oil to the top of your shock body. Make sure there is no air under the shock piston. Move it up and down several times..... Watch for air bubbles. Then stick the cap on. You should be good to go. Like the other guys said...rebound with no spring is a bad sign. lets try this again......
Dr.V
