Yes you can use it.
I've cut the tabs off and switched the wires, it works fine. I've also used an adapter which is a short extension with an old style on one end and a Futuba style on the other end. Or you can just cut off the old connecter and solder on a new wire. That would also give you a longer lead.
Tom
