connectors
Yes that is the way I change them..be careful when you reinsert them in the proper slot to give them a good tug to be sure they are locked in...I had one I bent too much when pressing down the spring tab..When I plugged it into the rec. one of the tabs slid back out just a tad..It worked when I first plugged it in, but then worked its way back out just enough to loose contact and the servo quit working...Glad it was on the ground and not in the air...On some servo plugs, You can also lift the plastic tongue very carefully to change the wires..I use a small t-pin and do it very carefully...Brian
