RCU Forums - View Single Post - Lash setting help needed
Old 03-05-2006 | 07:16 PM
loughbd
Banned
Default RE: Lash setting help needed
The valve lash is not that critical. All you have to do is make sure the rocker is not being pushed by the cam and then set the valve lash. As long as there is a slight discernable gap between the valve stem and rocker you are fine. There is really no way to get the lash exactl .015 using a feeler gauge. The best you can get is close. as long as they don't touch you are good.
