RCU Forums - View Single Post - help setting up FuntanaS 90 elevator
Old 03-05-2006 | 11:04 PM
dondee
Default help setting up FuntanaS 90 elevator
i need help setting up servo horn for elevator on FuntanaS 90, if i used "Y" cable i have to counter faced the servo horn (between left elevator and right elevator servo) but the lingkage travel and deflection has different measurement for the left and right elevator. I also tried program mixing on my JR 8310 using elevator -> Aux3 mixing but i cant trim elevator function from the digital trim next to the stick, i had to trim the elevator and AUX3 separetly (which is pain in the &%$*)
Please help me if anyone have other solution for this horn and linkage setting... I can reprogram the servo (if i used digital Hitec servos) but it will cost alot just for 2 elevator servos...
i tried to move the servo mounting so i can use "Y" cable without worrying about the linkage travel and deflection but the fuselage will look wierd...
thanks for any solution....
