Break-in sequence
Hello Bill
I have a Fuji-64EIS that has not been run as yet, and 250cc of Fuji oil.
I would like to run-in the engine using the Fuji oil at the recommended ratio's and then use the remainder of the Fuji oil for normal use (100:1).
I would like to switch to ordinary 2 Stroke oil at this stage. What is recommended, a mineral oil or a synthetic type????
If later on I switch back to Fuji oil will a second break-in be required as recommended if Ord 2/stroke oil is used then switching to Fuji oil.
Because of my Location (Australia) I understand that I am not covered by any warranty so I would not like to shorten this engines life due to lack of knowledge. This is my first Gas engine.
Thanks and Cheers Geoff
