Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
 shock flyer wing problem >
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 06-24-2004 | 08:11 AM
Default shock flyer wing problem
hi!
i have an Extra shock flyer... and i did a mistake:
i cut the the ailerons 70 mm from both sides instead one side only... and the ailerons now are a little smaller
than the original. Is it have influence on the flight? Can i continue with these or should I build another wing??
Old 06-24-2004 | 08:21 AM
larshkj's Avatar
Default RE: shock flyer wing problem
I did the exact same thing. It flies fine, but expect to get a little less effect from the prop-wash.
I bought a new one, but since the first flies fine, I will use that one until it breaks before building the new.
Lars
Old 06-25-2004 | 02:03 AM
My Feedback: (12)
i did the same on my first (still flying) shocky.
only prob i have is trying to align the carbon braces with the 3 plastic guides. make sure they wont pop out and use good bit of glue to hold em in.
