Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
 will this stuff work on the shocky >
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 06-25-2004 | 08:19 AM
suitcase's Avatar
Default will this stuff work on the shocky
anyone using these parts and are they good? I use the Futaba 6XAS radio.
CRX-M7 Receiver Type: 7 Channel Single FM Conversion
Range: 1.6Km (Full Range)
Operating Voltage: 3.5V - 6.0 V DC
Size L x W x H: 30 x 18 x 9.5 mm / 1.2 x 0.7 x 0.4 in.
Weight with case: 8.8 grams / 0.31 oz.
Weight with case
and antenna: 9.3 grams / 0.33 oz.
Shift: Negative Shift (GWS/Hitec/Futaba compatible
http://www.balsapr.com/catalog/recei...ductId=U571705
HES-490 Sub-Micro JR/Hitec Dimensions 0.79 x 0.28 x 0.63 in.
20 x 7 x 16 mm
Weight 4.8 grams / 0.17 oz.
Weight w/ Servo Wire: 5.2 grams / 0.18 oz.
Ball Bearings No
Metal Gears No
Torque (4.8V) 10 oz.in.
Transit Time (4.8V) 0.08 sec./60°
http://www.balsapr.com/catalog/trans...ductId=T020701
9 x 7 Slow Flyer Orange Electric Propeller (EP-9070)
All of this is from Hobby-Lobby.
IK2101 - EXTRA 330S SHOCK FLYER
PM220834C - COMBO: AXI 220834 & JETI 08-3P
PM22002 - RADIAL MNT FOR AXI 22 SERIES
IK2202AP - ACCY PACK: SHOCK FLYER BRSHLS
FM7003 - 3 CELL 11.1V 700MAH LIPO PACK (2)
ETC2500 - LI-POLY SMART CHARGER 1-4 CELL APACHE
What else do I need to get it together and flying?
Old 06-25-2004 | 10:04 AM
Wright Flyer's Avatar
Default RE: will this stuff work on the shocky
Almost everything there sounds fine but the usual prop choices for the 2208/34 on a shockie are 9x4.7 for 3S (like the cells you have) or 10x4.7 for 2S. If you use a 9x7 you may well pull more amps than you batteries and speed controller can bear (you'd be well over 8A that the Jeti controller is built for!).
Just one thing though - what C rating are the 700mAh cells. You may be pullling anything up to 7A (maybe even close to 8A). So they'd want to be 10C cells. As far as I know, unless they're a new type of 700, most 700 cells are only good for 5C-8C (meaning 3.5A-5.6A). You may be better off with either Kokam 340's (cos unusally they are 20C cells!) or the latest 830-850s that offer 10C or more (so at least 8A).
Cliff
