Recommendations For Tribute setup
NC
I have an E-flight Tribute but I haven't purchased the servos, motor, receiver, battery and esc. I am looking for an inexpensive setup that will allow me to hover and practice other 3d maneuvers. Please let me know what you are using.
You should use the hitec Hs-55 servos you need 4 and use whatever receiver you want we use the electron and then motor. It came with one right ? I dont know how much $ you want to spend but the Himax-2015-4100 and the 25 amp castle creation with 6.6 to 1 gear ratio on our foamies dad has the Ultimate from horizon he just got it lastweek and it flys great on this set up...
oh yeah the motors about $75 speed controller the same we use the 3 cell Li poly packs go to maxxprod.com they have all of this or go to fancyfoam.com he sells the stuff to.
hope this helps
hope this helps
NC
As I started putting together my list I starting thinking that it may be a good idea just to buy an edge 540 from fancyfoam.com with the high performance kit. I can put the electronics from the kit into the Tribute. Once I crash the Tribute I'll just transfer the electronics over to the Edge.
NC
Some people posted info about using the stock motor over on rcgroups.com and they said that it sucked. You can see the thread at http://www.rcgroups.com/forums/showt...4&page=1&pp=15.
PA
Here's my setup.
EFlite 370 5400 brushless - $48
Jeti 18 amp ESC - $60
Hitec HS55 servos X2 (I think around $20 ea)
Hitec HS81 servos X2 (probably $18 ea)
GWS Rx can't remember price, probably $20
Great Planes 1500 11.1V Lipo - $46
Thunder Power 860 11.1 Lipo $39
GWS 10x8 prop
GWS 10x8 prop
My Feedback: (75)
CO
Boy, this foamy is costing as much as one of my nitro planes[X(], I ordered the stock ESC yesterday and a 2 cell li-po, I wish I could of ask this question earlier, is the Eflight 370 brushless a direct replacedment for the stock 370?, will it fit the gear drive?, maybe I can return the ESC to Horizon for an exchange.
Joe
Joe
OH
Yes, it's the same size as the 370 so it fits right in.
Sure electric is expensive for the good stuff. So is gas the gas stuff. Don't worry, the performance is there.
My Feedback: (75)
CO
Well, I guess I'l look into parts exchange, I think the esc can be exchanged, but I not sure about the 2 cell li-po battery or maybe suck it up and upgrade later[:@]
Joe
Joe
My Feedback: (48)
CT
use the stock motor on 3 cells and you will get good performance. I have aver 40 flights on mine like this. A freind has the e-flight 370 motor on 2 cells and it is awesome perfomance it will fly straight up out if sight. I put my 3 cell on his plane with the 370 and it is just insane!!!
My Feedback: (75)
CO
Thanks for the input, I'm building it stock with the 2 cell li-po, this is my first foamy plane and electric, more like an experiment for future projects.
Joe[8D]
Joe[8D]
