Carbon control rods
CA
I use .070 inch carbon rod. At the control horn end, I just glue a mini nylon clevis to the rod using Gorilla glue.
At the servo end, I glue a short piece of inner nyrod to the rod, then use a short piece of 2-56 threaded rod or a cut off bolt and thread another mini clevis on for adjustment.
You can buy heatshrink tubing which has glue inside it. Just use this to attach some piano wire each end. I have also used standard heatshrink without any problems.
