3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
View Poll Results: A poll
They 're both good models.
100.00%
Voters: 6. You may not vote on this poll
Edited.
Old 11-01-2004 | 11:17 AM
My Feedback: (17)
Default Edited.
Old 11-01-2004 | 01:19 PM
My Feedback: (17)
Default RE: 3DFoamy VS insanefoamies
Old 11-01-2004 | 07:09 PM
3dandpatternflyer's Avatar
i never tried Insane Foamies but im more than satisfied with 3DFoamy. The customer service is great (levi) and the planes flight characterisitcs are outstanding. The assembly and the hardware is just fantastic.
3DFoamy!!!!
TTYL,
Andrew T.
Old 11-01-2004 | 07:20 PM
sky_dancer's Avatar
Can't comment on insanefoamies because I've never tried them. The thing is I don't know if I ever will because Levi at 3Dfoamy is such a nice guy to deal with. He will always be first choice for me.
Michael
Old 11-01-2004 | 07:23 PM
My Feedback: (17)
Old 11-01-2004 | 09:57 PM
Levi is top notch and his planes are well designed and fly well! Highly recommended!!!
Old 11-02-2004 | 04:22 AM
Well first up let me say i'm the Aussie distributor for 3Dfoamy, having said that both companies offer diferatnt planes with diferant pos and cons, but for $30 what can you say.
Old 11-02-2004 | 08:42 AM
tashley's Avatar
My Feedback: (9)
3D Foamy makes the best product I've run across to date. The main reason I would not try an insanefoamies kit is that they use blue foam instead of Depron. I've used both and I much prefer Depron. As far as construction is concerned, I can't imagine anyone having problems with assembling a 3D Foamy kit.
Old 11-02-2004 | 09:33 AM
My Feedback: (17)
Old 11-02-2004 | 09:53 AM
tashley's Avatar
My Feedback: (9)
I know what ultrafoam is. It is made by Dow and is the same as blue fan fold foam except that it has a white core with a plastic outer layer and does not have the pin holes and waves as the standard fan fold foam has. If you stress it, you will have wrinkles on your nice smooth paint job. It is somewhat tougher than Depron but is somewhat heavier. Take your pick.
Thank you for your offer but I have all the ultrafoam samples I would ever need. BTW, are you sure you're not Kris^?
Old 11-02-2004 | 10:20 AM
My Feedback: (17)
Old 11-02-2004 | 03:03 PM
Levi_Jordan's Avatar
My Feedback: (21)
Anyone do boxing??? maybe we should "step outside"
I think its a personal preferance. Maybe you should start a new "Poll" and find out what the majority of modelers think of Depron Vs/ FFF (Ultrafoam)
Old 11-02-2004 | 03:29 PM
tashley's Avatar
My Feedback: (9)
Or perhaps a poll showing how many kit companies, who can supply any material they may choose, use one or the other.
Old 11-02-2004 | 03:32 PM
My Feedback: (17)
Old 11-02-2004 | 03:43 PM
My Feedback: (21)
I am glad that you are supporting Insane Foamies. (Really) It's guys like yourself that make what he and I are doing happen. After all, how boring would it be if all you could get was 1 single design?
I like that fact that the insane foamy designs are so much different than mine. There will be clear supporters of both, and I don't think that either side has a "Real" advantage that would make you switch. If you have found something that works for you... go for it.
I can appreciate your point of views on it, and hope that you'll continue to support him and his planes.
Old 11-02-2004 | 04:12 PM
My Feedback: (17)
Old 11-02-2004 | 04:24 PM
My Feedback: (21)
No Problem... I appreciate all you have said. It spured my brain to a new solution for the "Spar Process"... I'll have to do some playing around now... See good comes from most things if you look for it.
Let me know whe you are ready for that next airplane.. It's on the house... Just e-mail about it.
Old 11-02-2004 | 05:41 PM
tashley's Avatar
My Feedback: (9)
Levi, you're the kitter and it's your business if you want to change your designs, but IMO the spar works like it should, is simple in design, and even if you don't own a Dremel with base it's really no problem to cut the spar slot out with a sharp nr.11 blade and a straightedge. Just make a couple of v-cuts and round out the slot by dragging the spar material through it. If you do own a Dremel and base you can do a lights out and speedy job of it.
ID:	189257   Click image for larger version
Old 11-02-2004 | 05:49 PM
My Feedback: (21)
Default RE: Edited.
Ageed... I thought up a new one thought that should be even easier... and lets that laser do the work for ya. It should also make the wings stonger, and fly getter too.... Cross your fingers. I'm sending a new CAP with the new spar system off to Crash to do the tests on it... Hopefully we'll here a report back. (Sending some CA and kicjer along too)
Old 11-02-2004 | 06:12 PM
My Feedback: (17)
Default RE: Edited.
I will give a detailed description. I will hold off on the construction of my Edge so I can follow up with a flight report. Something tells me that I am about to eat my words.
One thing is clear already. Levi is an honorable man, willing to do what he can to satisfy his customers. I can see why he has such a loyal fan base.
Old 11-02-2004 | 06:35 PM
Default RE: Edited.
Crash, Sent you a PM
Old 11-02-2004 | 07:02 PM
tashley's Avatar
My Feedback: (9)
Default RE: Edited.
That's why those who know him, call him "Da Foam King".
ORIGINAL: Crash90
