Prop for e-flight park 400 outrunner
it's not actually that motor, but one VERY similar. it is an Xmotor 400, mine is 750Kv, e-flight is 740Kv
anyway, back to the point, what prop would you recomend
-richo
-richo
NH
APC electric 11x4.7 wouldn't be a bad prop to start with for 3D flying. A 10x4.7 would work good for smaller planes or if things get too hot with the 11x4.7
Guys...what do you think a good range (of props ) would be for the 920kv Park 400?
I'm designing a foamy similar to the Tribute, but a little smaller...
NE
I have the E-flite 400 920 kv. It turns gws direct drive 9x5 at 8600rpm at 9.8 amps.
It also turns a gws 10x6 at 7600rpm at 12 amps.
I was thinking of running it in the Mini Funtana that I have.
What do you think?
Don
What do you think?
Don
It'll probably fly, but thrust won't be much more than weight unless you've built it very light. So don't expect to hover, except maybe at full throttle.
