3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Flatout
Old 07-07-2005 | 04:56 PM
Default Flatout
Folks, I have been asked to assemble a flatout for a friend but
have no experience with this type of model. The instructions say
to glue the servos to the model. Now do I CA them down or use
some other method?
Thanks for any help.
Jerry
Old 07-07-2005 | 06:13 PM
Default RE: Flatout
You can glue them with CA. If needed, they can be pryed out with a small screwdriver. I crashed a Cap 580 and popped the servos out with no problems. I am almost finished with my flatout. Can't wait to try it out.
Old 07-07-2005 | 06:31 PM
JohnVH's Avatar
My Feedback: (38)
Default RE: Flatout
I CA the servo's into all my foam aircraft. Youll get them out when you need to, sometimes Ill put a wrap of tape around them if I want them to stay clean for other installs.
Old 07-07-2005 | 08:32 PM
Kevin Greene's Avatar
My Feedback: (85)
Default RE: Flatout
I use a dab of Goop adhesive on each of the servo ears---Easy to pry loose if you need to and offers a little vibration protection. Just don't get any on the foam as it will eat it. (The Flatouts have a plastic frame that the servo slides into.)
Kevin
Old 07-07-2005 | 08:40 PM
Default RE: Flatout
i wrap mine with paper masking tape and use gorilla glue
Old 07-07-2005 | 08:51 PM
Default RE: Flatout
I use a little hot glue on the ears or on a corner depending on how it is mounted.
Now you have a few options. I'm sure the foam safe CA works fine but I have heard
of people getting it inside the case and junking the servo.
Good luck,
Pete
Old 07-08-2005 | 05:43 AM
Default RE: Flatout
Thanks for the suggestions and comments.
Jerry
Old 07-08-2005 | 07:12 AM
exeter_acres's Avatar
Default RE: Flatout
I use Hot glue as well
Old 07-08-2005 | 03:28 PM
Default RE: Flatout
Never thought of Hot Glue. It sounds like the best choice all around. I'll use it on my next one. [8D]
Old 07-08-2005 | 09:17 PM
My Feedback: (19)
Default RE: Flatout
ORIGINAL: AlvinS
Wrap it in good masking tape first. It protects the servo, and gives the hot glue something better to stick to then the shiny servo case. ;-)
Regards,
Lee
