3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
cap 580 flatout
Old 09-26-2005 | 12:20 AM
Default RE: cap 580 flatout
anyone got a short vid ...........it would be great thanks
Old 09-26-2005 | 12:26 AM
Banned
no kidding this plane must really not be anygood ...yak54f fans at least post videos
heres my short clip [link=http://www.rcgroups.com/forums/showatt.php?attachmentid=568595] shortyak prophanging clip[/link]
as soon as i build this cap580 i will make a clip ...good news is i just got the esc so im ready, just need more ca glue[]
the 8amp esc is so tiny its cool looking makes my eflite20amp look huge...lol...\
im getting real excited i have a crease in wing i dindt make so i might return the wing to the hobby shop and get new one..
Old 10-10-2005 | 06:58 PM
how does this plane preform with the stock motor ????
i dont want to pay the extra for a brushless upgrade
Old 10-10-2005 | 07:23 PM
Banned
THE BRUSHLESS IS A MUST FOR ANY 3D PLANE ITS WORTH THE EXTRA MONEY
Old 10-10-2005 | 07:49 PM
i dont really want to do much 3d with it i mostly was wondering about the stock motor because i want something to fly at my house because the nearest flying field is almost 45 minutes away
Old 10-10-2005 | 10:12 PM
  #31
fingers73's Avatar
I had 2 of the 580's. the first 1 went in because the plastic standoffs for the empenage bound and locked the controls. The second lasted a long time with care. A few things to keep in mind with this plane. #1 keep airspeed down, high g's will fold it up as fast as you can blink an eye. That was the end of mine! #2 using an outrunner, a prop saver is a must the wimpy landing gear will let the prop strike the ground. Also this empenage addendum is over complicated, just put the elevator servo and horn on the other side, problem solved. As for as flying it will flat spin awesome, slow flight is stout with the big controls. It does however have terrible coupling. It hovers rock steady, oh yah and again keep the airspeed way down unless you want 90 degrees of dihedral. As stated earlier it does look pretty in the air, I have many photos that look really good.
Old 10-10-2005 | 10:34 PM
  #32
Vertical3-D's Avatar
My Feedback: (20)
Yeah, mine was looking good, and POP, sounded like someoone popped a paper bag, and it was at least 15 feet up, spiraled in, caught it at 50 feet, throttled up, and as soon as if moved forward the wings folded again and in she spun. None of the on the Flatana Ill tell you that, My new ultrafly Radix is also a wonderful plane.
Old 10-10-2005 | 11:53 PM
  #33
Banned
im cutting apart a bass fishing pole to make wings stronger then!!
Old 10-11-2005 | 12:07 PM
  #34
i think im just gonna have to buy one
ill try all this stuff out for myself
Old 12-20-2005 | 01:07 AM
  #35
Banned
HOW DO YOU MOUNT THE RIMFIRE ON THE SILVER RING IS TOO BIGG TO FIT THROUGHT THE PLY ADAPTER HOLE SHOULD I REMOVE THE HEX SCREW OR WILL THIS MAKE THE MOTOR FALL APART
Old 12-23-2005 | 07:38 AM
  #36
Scott Dilley's Avatar
remove that ring. I think it is for the "thru the firewall" mounting option.
Old 12-23-2005 | 12:07 PM
  #37
Banned
are you sure!!! i read somewhere that you just need to drill the ply hole bigger to fit ring through so i did someone said if you remove the ring that the hole motor will fall apart as soon as the lock washer wears out .......i hate that rimefire and great planes has no info on this subject.................i hooked my 3 cell 1320 li-po up, to that rimfie it was so fast the plane started to get the shakes lol...........my tribute and yak54f can handle that extra power !!!i have the cap 580 and tribute ready to run the yak was crashed badly .....the power of the 4100kv brushless inrunner w/gearbox is insane compared to the rimfire.........i flew the cap 580 and i used a 2 cell 860 li-po with 9x4 prop well prop too small for that setup and it landed hard after the auto half power esc kicked in so i reprogramed esc to not turn power down and put the 10x3 prop on which rimfire recommends props 10x3.8,10x4.7,11x3.8 for 2 cel li-po
...............8x3.8,8x6,9x3.8 for 3 cell lipo
....so i was using the wrong prop on my 1st flight[sm=idea.gif]
Old 12-23-2005 | 12:31 PM
  #38
I fly a 9 oz. self designed foamy with 256 squares on the rimfire and 640mAh 3S with an 8x4 to a 10x3.8 and with the 8x4 it hovers at half, and with the 10x3.8 it hovers at less than a third. I don't think I'd want anymore power than that.
Old 12-23-2005 | 08:51 PM
  #39
Banned
(256 squares ) whats that mean ....sounds nice ....i flew the tribute today and wow what a responsive plane that is i miss the yak54f because i built it on the control horns to be not so responsive ...the tribute threw me off and was very nerve recking to fly i think i got a yak54f for x-mass though...cant wait to get my favorite flying plane back
Old 08-03-2006 | 03:52 PM
  #40
Hey, I am 16 years old and i just purchased my first 3d plane and its the cap 580, now ive been practicing flying it on the Realflight G4 and to me it handles ok. i need to know when im finished building it what electronics should i use from esc to motor and servos and battery? if any of you guys have video of you flying your plane. I havent started building it yet but give me some helpfull tips.
